For the original poster (OP) to fill in:
Introduction
A temporary run once, self contained client to create a quick Xibo display.
User Story
We have an upcoming event and we’d like to setup some more temporary Xibo displays. We’re using some laptops and PC’s which would normally be used by users but for this event we’d like to show a Xibo layout. To do this at the moment the client must be installed, configured, approved and the layout push out to it. Once the event has finish the software must be removed and Xibo CMS cleaned up.
The request is to create a temporary, self contained client which doesn’t need to be installed. You’d pre-config and approve it via CMS. This would create a client file (EXE on my case) which would be run on the device. At the end of the event, you close the client, delete the file and remove the ‘Temporary’ display from CMS.
For the dev team to fill in:
Status
The current status and the username of the:
- Reporter
- Drafter
- Implementer
Implementation
A broad description of the changes required.
Effected Software
Which parts of Xibo are effected
DB Schema Changes
Any necessary DB Schema Changes
