Fade in / fade out with Win Player
Hello together,
is this Problem by windows player meantime solved?
best reagrds
It isn’t supported on Windows. It isn’t supposed to do it.
It won’t work until there is a newer Player for Windows that has that capability. We can’t do it with the way the Windows Player works currently.
That is really a shame. I think such effects make digital signage … but o.k. That’s why the software is also free.
