Hi, i would like to know if it’s possible how extract then publish many layout in same time ?? ( select all then extract then publish ) thank’s
With XiboMultiSelectFormButton
Can you please explain what you mean by ’ extract '? I believe there is no such option in the CMS
Hi Neal, excuse me for my bad english i traduct from french " in the row menu " from the layout under conception.
My prolem that i have a lot of layout and i would like update all my layout in the same time with select all ( then in row menu : extract and publish )
Which option do you mean?
I get what you mean by “Publish”, but not by “Extract”
Maybe you could ask in French?
it’s ok thank’s for all
@dan
Hello, is there any way to publish several layouts at the same time? for example, I have several layouts with the same playlist, when it is edited I have to publish one layout at a time. how to select multiple layouts and publications at the same time?
You don’t need to draft layouts which use a playlist - they will automatically get rebuilt in their published state.
