Can someone point me in the direction of getting xibo running on a external server run by 123-reg on domain?
Xibo isn’t suitable to be run in a shared hosting environment. You need a VPS or dedicated server to run it properly.
Thank you, is there any other open source application that can you can recommend? Thanks for speedy reply!
