hi,
When i try to export layout, i have an error web page :
can someone help me to resolve this problem??
hi,
As a first step, please correct the CMS configuration, as you should not have /web in your CMS URL, please see - https://xibo.org.uk/docs/setup/prepare-your-environment
Thank you for answer,
i make the change about document root and url rewriting, i have the same error :slight_smile :
Note the export is done correctly in an another layout
I resolve the probleme by setting the field “field download mode” to apache
