Export Layout IIS
Good Morning,
I have the problem that when wanting to export a slide I get the following error: The webpage at https://digitalsignage.wolfcom.com.ar/layout/export/16?includeData=on might be temporarily down or it may have moved permanently to a new web address.
ERR_INVALID_RESPONSE
I have version 1.8.2 installed on a Windows Server 2012 IIS
Regards,
There’s a few possibilities, all of them PHP related.
You might not have the PHP zip module enabled, or you might not have a high enough PHP memory limit, or you might not have a high enough execution time. Building layout exports is “expensive” from a compute and memory point of view.
You’re hitting one or more of those limits, and you need to look at your PHP logs and see.
How would the PHP ZIP file be enabled?
Here, try it and let me export a small slide, where I should increase the size to download it?
So you’re hitting memory limit, maximum execution time, or running out of temporary storage space.
Thank you very much Alex! Change the memory limit and it works perfectly!
Regards,
