Explorer 8 Login Problem
Hello, I am using 1.4.x for my some projects. There is a problem sometimes when I try to connect xibo cms from explorer 8. It is not login. Everytime loops and the login page comes again. How can I solve this problem without upgrading the explorer. It happens in 1.7.x or not?
If I upgrade Xibo is it ok?
We would definitely recommend an upgrade to 1.7.4, you can have a look at Release notes
In your case, in would be probably 1.4->1.6->1.7.4
That being said, perhaps your main problem has something to do with browser cache? Did you try to clear it? Or use other browser?
