Executing Shell Command
I’ve just installed xibo on WAMP. So obviously I’m very new to it.
I was looking for a way to execute a command from batch file or at least to use a shell command. But it seems that I’m too dumb because I just can’t find a window where I can enter my command. Can anyone tell me where I should look for a Windows Command line in Xibo? Or a way to implement batch file.
Thanks.
1111,
There is an option for shell commands in the layout designer.
Shell commands work on Windows and Rooted Android Devices, if Xibo on Android has been given Root Permission.
Thank you! And I spent like two hours searching for it.
