Version 3.1.0 (RUNNING ON DOCKER)
Android/Windows
I have 2 datasets,
dataset_3 - with column names - Name, Status.
dataset_4 - with column names Status
I want to pick the dataset value of the column “Status” based on a specific name (for example-Mukul) and put the value in Dataset_4 column Status.
This is what I have done:
Create the “status” column in dataset_4 as “Formula” and added the formula "Select Status from dataset_3 WHERE Name=“mukul”;
Somehow I am not able to get it working. Can somebody please guide me in the right direction to get this done?
Regards,
Mukul
