Events repetitions
Hello
I have a layout that has to run every 5 minutes for 2 minutes from 1700 to 2130 every day.
Is there a way to set up the event or would that be something for the next update?
You could create 2 min long event to repeat every 5 min, but that’s not recommended, as it will create a lot of events on the Schedule page.
I’d suggest manipulating the durations of scheduled events instead.
So you could have a campaign with x layouts, the duration of the campaign would be 5min (including the layout you mentioned), then you’d schedule that campaign to run from 5pm to 9:30 pm - ie that would be one event and the playback would be the same.
