Error message on log using android player
While send the content i am getting this message in log
errormsg>fopen(\Library/jquery.marquee.min.js): failed to open stream: No such file or directory
2
Warning
/home3/crystubw/public_html/chandv/lib/service/xmdssoap4.class.php
591
what is the issue
Your Server Library path is invalid at a guess.
It should be a fully qualified path to the library directory, so for example
C:\XiboLibrary\
Or
/opt/xibo/library/
Wherever you have that located. Relative paths are not allowed.
fread() expects parameter 1 to be resource, boolean given
2
Warning
595
what is this error shows pls help
Is that error new after you changed your library path?
If so, are your library files all actually at the new path you’ve configured?
