I deleted the .htcass file from the directory / xibo / web /
and executed the path manually in xibo / web / install / index.php so the loop didn’t happen anymore, but an error on the installation page was presented as shown in the image below:
You must not have web in the URL you’re using to access the CMS. What you’re doing there is wrong.
Please check the install guide, and better still, use the method we suggest for install (with Docker). We don’t offer support for custom installs here as there’s just too many variables for us to help people in a reasonable amount of time.
Only the web folder should be exposed to the Internet. Please read the installation guide which explains your options, however, shared hosting very often doesn’t allow the changes you need and so in general we say it isn’t suitable for use with Xibo.
The CMS is alot more intensive than it used to be, and you need to be able to run PHP applications from the command line not just from the webserver
