Every time I touch the touchscreen, a bar providing access to the monitor settings opens at the top of the screen; how can I disable this?
XIBO Player version 4.0.
13.
Best regards, George
Is the widget a web page ? Touch / click in webpage widget doesn’t seem to be supported.
Hello Romolo,
No, this is not a website widget; it is a JPG image.
The error occurs whenever there is any touchscreen interaction, mouse movement, or keyboard input on the XIBO monitor—regardless of the widget being used.
Regards, George.
We’re working on our touch support.
This is the feature needed to support your use case: ActionBar timed mode · Issue #270 · xibosignage/electron-player · GitHub
