I installed Xibo on my own server and it works fine.
To try out how it works, i installed the Xibo-Player on my Android-phone.
when i try to connect the CMS, i get allways the massage:
"Unable to Register as the CMS has sent an error. Bad Request"
The CMS-Key is checked about 20times
You will need to change DocumentRoot and URL rewriting (please see notes fort your environment).
Once make those changes please see if the issue persists - if it does you can go through Report Fault wizard to see if there will be any additional logs.
That will depend on your server environment - URL rewriting has notes for different servers, as for DocumentRoot, if you do not know how to change it in your server, you can perform a quick google search about it, I’m sure you will find the answer - I do not know what server environment you’re using, therefore I can’t tell you where exactly you need to make those changes.
I cant install it like in the Install-videos because the xampp has PHP 7 and xibo works with PHP 5.
Directly installed in de web-server is working, but the result is the same (…/web).
move or change the .htaccess-file has the result of Fatal Error 500
I think, i’m just too stupid to install xibo
I can’t find any videos to install the xibo directly on de web-server.
