Error Adding Display
3-R305.1-win32-x86
#CMS Version
3.06
Hi All, I am trying to register a new display and ma getting the error logged back in the CMS “Please enter a display group name”. This is a new site we are adding to Xibo, we can install at existing sites and its working fine. I have checked firewalls and cannot see anything getting blocked.
The player software displays the message
"Status
Client found response content type of ‘text/plain;charset=UTF-8’, but expected ‘text/xml’.
The request failed with the error message:
There has been an unknown error with XMDS, it has been logged. Please contact your administrator.
has context menu"
Provide screenshots where possible!
Thank you for your message and for the details regarding your issue.
Please can you close the Xibo player on that machine and open a web browser. Are you able to log into the CMS you are trying to connect to?
Can you also make sure that:
  • You have entered the CMS URL correctly, including using HTTP or HTTPS appropriately, depending on how your CMS is set up.
  • The time, date and time zone are set correctly on your PC running the player.
  • Are you certain that you are using a version 3 CMS and player? Please can you check to make sure this is the case.
