Error access denied for logout
i get this when a teacher tries to log out and i believe i have gave them the correct permissions to be able to, they can do every thing they need without issue but sign out
Are you running a CMS version earlier than 1.8.4 by any chance?
If you do then it’s probably this bug - https://github.com/xibosignage/xibo/issues/1345
no 1.8.3, if not its not an issue really
I rephrased my previous post, just to make it clear the issue with logout is fixed in 1.8.4, before that as you’ve noticed there was an issue with permissions to this page.
yea thanks ill upgrade soon
Thank you
