Embeded weather iframe update
I’ve a layout displayed for 4 consecutive hours. The content is static.
To avoid the visible refresh on every loop I’ve adjusted the duration to 86400 s in case I’ve to display this layout an entire day.
The only non static zone is a weather iframe. The duration is adjusted to 900 to refresh the content every 15 minutes.
But the weather is not refresh unless i restart the xibo client.
How can I do to avoid the visible flickering on every update to avoid to set duration of the layout longer than is scheduled ?
Thanks !
mmm am I right to guess that your ‘weather iframe’ is alone in the region?
You’ll probably want to add duplicate ie the same ‘weather iframe’ to that region so then when they switch, it should refresh that region.
thanks, I will try your suggestion.
