Embedded HTML saving problem
Hi
Save and Apply button for Embedded HTML in layout design doesn’t work anymore for both new or existing media contents.
Pressing the button it appears a rotating wheel and no action is taken. Previously it worked without problem
Xibo version : 1.7.5 / 1.7.7
PHP version : 5.6.20
All the environment passed all the Xibo Environment checks.
Roberto
It could be good to upgrade to 1.7.7 and do ‘verify all’ routine on Modules page.
The [quote=“bobrovel, post:1, topic:5938”]
[/quote]
might be a php/web server issue, did you change anything since it last worked fine?
Is it only with embedded module or also with other modules?
Any errors in logs? (assuming you enabled logging)
First design implementation was in 1.7.5 and it worked correctly.
When i found the problems (some months later) i did the upgrade to 1.7.7 but without success and all the modules are verified…
At this time i found problems only with embedded modules . Text Modules are working fine.
I’m running Xibo on a hosting and i’m not shure that nothing is changed on server side.
All the environment checks are ok and the PHP version is the following :
PHP Version PHP version 5.3.3 or later required. Detected 5.6.20
This is the log for the embedded html saving operation . I don’t see any error …
54166 16-05-10 01:09:35 CMS User DisplayList SQL: SELECT display.displayid, display.display, displaygroup.description, layout.layout, display.loggedin, IFNULL(display.lastaccessed, 0) AS lastaccessed, display.inc_schedule, display.licensed, display.email_alert, displaygroup.DisplayGroupID, display.ClientAddress, display.MediaInventoryStatus, display.MacAddress, display.client_type, display.client_version, display.client_code, display.screenShotRequested, display.storageAvailableSpace, display.storageTotalSpace, currentLayout.layout AS currentLayout, currentLayout.layoutId AS currentLayoutId FROM display INNER JOIN lkdisplaydg ON lkdisplaydg.DisplayID = display.DisplayID INNER JOIN displaygroup ON displaygroup.DisplayGroupID = lkdisplaydg.DisplayGroupID LEFT OUTER JOIN layout ON layout.layoutid = display.defaultlayoutid LEFT OUTER JOIN layout currentLayout ON currentLayout.layoutId = display.currentLayoutId WHERE displaygroup.IsDisplaySpecific = 1 ORDER BY displayid. Params: array (
54165 16-05-10 01:09:22 CMS module SetMediaInformation Existing Assigned Media XML is: \n <?xml version="1.0"?>
0Borsa0
<![CDATA[ ]]><![CDATA[]]><![CDATA[
54164 16-05-10 01:09:22 CMS Layout GetLayoutXml OUT
54163 16-05-10 01:09:22 CMS Layout GetLayoutXml IN
54162 16-05-10 01:09:22 CMS module Module created with MediaID: ad4053b716e55301e8387e7cbe509677 LayoutID: 5 and RegionID: 1111325745568c0c94e0880
54161 16-05-10 01:09:22 CMS module Creating new module with MediaID: ad4053b716e55301e8387e7cbe509677 LayoutID: 5 and RegionID: 1111325745568c0c94e0880
54160 16-05-10 01:09:20 CMS module SetMediaInformation Existing Assigned Media XML is: \n <?xml version="1.0"?>
0Borsa0
54159 16-05-10 01:09:20 CMS Layout GetLayoutXml OUT
54158 16-05-10 01:09:20 CMS Layout GetLayoutXml IN
54157 16-05-10 01:09:20 CMS module Module created with MediaID: ad4053b716e55301e8387e7cbe509677 LayoutID: 5 and RegionID: 1111325745568c0c94e0880
