Hi there,
I have inserted Temperature display module in a layout using embedded html which obtain data from openweathermap.org. It looks perfect by looking “preview layout” tab. But the player doesn’t display the temperature display region. I have linux player used. How can I solve this problem? please help.
have you checked the the temp zone area order as it should be on top of the main one
