I’m testing android (1.8 R108) and windows(1.8.10) demo players and I’m having some issues with Embedded HTML widget when the player is without internet.
I’d created a layout with an embedded widget and wroute a simple html inside:
“div-tag>SOME WORDS</div tag>”
When the player has internet connection, it works fine. But without internet connection it doesn’t show the content i’ve wroute inside the div tag.
I had read about some similar issues. I’ve check the option “Enable caching of Web Resources?” and increase “Send files in advance?” number.
This same layout works fine in windows in both cases (with internet and without internet).
Embedded HTML is downloaded locally so should show fine offline.
The caching options only relate to external content.
You’re certain that the Player has the embedded HTML downloaded before you disconnect it? It won’t download until it has run the content for the first time in some cases.
Hi Alex,
Thank you for your answer.
I’ve test this in many android hw and also on a virtualized Android ( VirtualBox 5.2.10 and Android Lollipop if you wanna test it ).
I thought that too
And yes. I made sure it was completely downloaded. The code is as simple as I wrote it before.
I’ve made some other tests and I’ve notice that this happend after the second app restart (killing and starting it manually).
Thank you for your patience. the issue is still currently being investigated by the Development team. I have a note to contact you when the issue has been resolved so you can download and install that revision.
Thank you for your message. I have been testing the version 2 Xibo for Android Player and have found that the embedded HTML is remaining on my screen even after I remove the network connection. have you tried using the Version 2 Android Player to see if this resolves your issue?
[quote=“DanBW, post:11, topic:17288”]
The HTML remains on screen if you remove the network connection but don’t restart the Player?
[/quote] Yes!
Was it necessary to restart the Player twice for the HTML to be lost? Is that to say it remained stored for the first restart?
[/quote] Also yes!
HTML remanins on screen if you restar the player once.
I have also tested this on the latest Xibo for Android Player, currently the issue is still present. I have spoken to the development team who have confirmed the issue is still with them for a fix to be created for a future release of the Xibo for Android Player. I have added a note for myself to contact you once I have confirmation that the issue has been resolved. Thanks again for your patience.
I have contacted the Development team regarding this issue and can confirm it is still ongoing currently, my apologies for the time taken. I still have a note to contact you as soon as the issue is resolved, thank you very much for your patience.
This message is to let you know that the fix for that issue has now been completed and added to the latest Xibo for Android release, which is Version 2 R203. The APK is available at the below link:
