I am not sure if this is because I am using a non-docker install. The weird thing is all the other players I have tested work fine.
Is there something I might be missing in my configuration to make the Electron player download from the server?
Electron player is still in beta version.
Try set display to 1 minute update interval and reset player to try to fetch new layouts.
Is there any way I can help with beta testing?
Figured it out. I had to actually schedule it. Having it as the default layout did not download it.
Yes, you can join the beta testers group. @natasha
I have added you to the Beta Tester group for Linux and you should receive a notification.
Thank you for your support.
