Duration Setting Cannot Be Changed (Defaults to 10secs)
I am experiencing an issue where in the layout editor when I choose to set a duration and click save the value does not change and remains at default (10 secs). In fact when I click the widget after ‘saving’ the changes, it does not have ‘use duration’ checked off. Has anyone else had issues like this with Version 2.0.1?
Thanks in advance for anyone’s assistance/guidance.
Edit: Only appears to be with PowerPoint presentations. I am able to change duration of websites/pdfs.
Thank you for your message and welcome to the community!
I have been testing the Powerpoint Widget in 2.0.3 and I have not experienced the same issue as you have.
To demonstrate, I have included below a series of images showing me updating the Duration of my Powerpoint Widget:
This is the default duration of my Powerpoint Module, I have set it to 120 seconds:
Next I open a new Layout and add the Powerpoint Widget:
The Set a duration box for the Widget is unticked so I tick it, set the duration to 20 and click the blue Save button in the Edit Widget window. You can see I receive the edited widget notification at the top of the screen:
Finally I publish the Layout to confirm this is the final configuration for the Layout. After I published the Layout, I then clicked on the Powerpoint Widget, which shows that the Duration has remained at 20 seconds.:
If you are also doing the same as I have done above but the duration is not retaining the changed value, please upgrade your CMS to 2.0.3 to see if the issue is resolved. If the issue persists after the upgrade, please let me know.
