error in publication
this message “Draft - Publish Failed” appears in the 2.3.9 statuses
publishing is automatic for 30 minutes, but not
Does the ‘Publish Now’ functionality work as expected?
Do they Publish as expected if you enter a date/time? (with the default disabled)
Could you also confirm if this is a Custom or Docker based installation?
Thank you
