Doesn't load the layout on player while connected
I added 5 screens to my cms. CMS is without SSL.
4 of them are connected by LAN and 1 by WiFi.
The 4 with LAN are working correct. The one with WiFi has some problems.
In the CMS it says it is connected and logged in etc. Last accessed 5 min ago.
I scheduled a layout but it isn’t loaded on the player. Pretty weird because if I set a default layout from the CMS for the player it does work but. Opening the options and save the configuration gives me ‘Display is active and ready to start’.
If I press ‘i’ in the player I see the following error:
Error swapping to HTTPS. E = Unable to connect.
Didn’t enable force HTTPS in my CMS.
How can I solve this problem?
I’m new using XiBo and I have a similar problem.
In the CMS my displays are connected, I can request screenshots, displays are authorised.
But when I schedule a viewing, the player stay stuck on initial splash screen.
When I manage the display on CMS, I can see that only 2 files are downloaded and 20 are pending.
When I press “I” in the player. I Don’t have erred but that said I was not connected.
“XMR Status; Disconnected, waiting to reconnect, last activity: 01/01/0001 00:00:00”
I don’t know if I did something wrong in the config or maybe an access problem…
