I am researching Digital Signage software for an upcoming project. I would like to see if Xibo could solve my issues.
I need to have two separate Digital Signage CMS sites. I do not want to run 2 separate servers. Once will be for a couple internal TVs that will display HR information, the other will be customer facing and have product demos and not include the sensitive employee data. My question is can Xibo support running 2 separate CMS sites, maybe delineated like http://xiboserver/CMS1 and http://xiboserver/CMS2?
Also, my output will be going to into a private cable TV system, we will be broadcasting 2 HD channels over coaxial cable media. So the TVs will not be network. Can I simply install the player on a media player PC and have this output to HDMI to feed the CATV system? I already have pinpointed the distribution system, all I need is an HDMI output for the CMS sites, I figured a simple PC running the Xibo Windows client would work.
