I am not good at English. I am sorry.
I have checked the following environment and it does not work in screen saver mode.
CMS:2.3.8
Player:windows 2 R256.7-256
When I debugged it, I got the following error.
Could not load file or assembly “System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a” or one of it’s dependences. The found Assembly’s manifest definition does not match the Assembly reference. (Exception from HRESULT: 0x80131040)
Then I noticed that there was no config file in “Xibo.scr”.
I copied the file “XiboClient.exe.config” and put the file name “Xibo.scr.config”.
Is this the right way to handle it?
Also, if the response is correct, can I have “Xibo.scr.config” included in the installer?
