Hello Peter,
thanks for your fast answer.
Yes i hav enable the checkbox right!!!
here’s the log from the xibo webinterface:
218408 18-02-01 11:58:54 CMS User DisplayList SQL: SELECT display.displayid, display.display, displaygroup.description, layout.layout, display.loggedin, IFNULL(display.lastaccessed, 0) AS lastaccessed, display.inc_schedule, display.licensed, display.email_alert, displaygroup.DisplayGroupID, display.ClientAddress, display.MediaInventoryStatus, display.MacAddress, display.client_type, display.client_version, display.client_code, display.screenShotRequested, display.storageAvailableSpace, display.storageTotalSpace, currentLayout.layout AS currentLayout, currentLayout.layoutId AS currentLayoutId FROM display INNER JOIN lkdisplaydg ON lkdisplaydg.DisplayID = display.DisplayID INNER JOIN displaygroup ON displaygroup.DisplayGroupID = lkdisplaydg.DisplayGroupID LEFT OUTER JOIN layout ON layout.layoutid = display.defaultlayoutid LEFT OUTER JOIN layout currentLayout ON currentLayout.layoutId = display.currentLayoutId WHERE displaygroup.IsDisplaySpecific = 1 ORDER BY displayid. Params: array (
218407 18-02-01 11:58:47 CMS Userdata entries SQL:
SELECT user
.userId, userName, userTypeId, loggedIn, email, homePage, lastAccessed, newUserWizard, retired, userGroups
.groupId, userGroups
.libraryQuota
FROM user
LEFT OUTER JOIN (
SELECT group
.groupId, group
.libraryQuota, lkusergroup
.userId
FROM lkusergroup
INNER JOIN group
ON group
.groupId = lkusergroup
.groupId
AND group
.isUserSpecific = 1
) userGroups
ON userGroups.userId = user
.userId
WHERE 1 = 1
AND user.retired = :retired ORDER BY username. Params: array (
‘retired’ => 0,
218406 18-02-01 11:58:46 CMS User DisplayList SQL: SELECT display.displayid, display.display, displaygroup.description, layout.layout, display.loggedin, IFNULL(display.lastaccessed, 0) AS lastaccessed, display.inc_schedule, display.licensed, display.email_alert, displaygroup.DisplayGroupID, display.ClientAddress, display.MediaInventoryStatus, display.MacAddress, display.client_type, display.client_version, display.client_code, display.screenShotRequested, display.storageAvailableSpace, display.storageTotalSpace, currentLayout.layout AS currentLayout, currentLayout.layoutId AS currentLayoutId FROM display INNER JOIN lkdisplaydg ON lkdisplaydg.DisplayID = display.DisplayID INNER JOIN displaygroup ON displaygroup.DisplayGroupID = lkdisplaydg.DisplayGroupID LEFT OUTER JOIN layout ON layout.layoutid = display.defaultlayoutid LEFT OUTER JOIN layout currentLayout ON currentLayout.layoutId = display.currentLayoutId WHERE displaygroup.IsDisplaySpecific = 1 ORDER BY display. Params: array (
218405 18-02-01 11:58:45 CMS Login with referring page:
Can You see there an misstake?
OK. and which options do I have to get a layout ad again?
138/5000
On schedule I can select the layouts / campaigns, but I just can not change layout or edit in the tab “layout”
best regards
