I have set my Current Layout however its not showing
how do i fix this, the layout should always been shown
I am currently using Xibo Cloud Hosting Solution
So, there is a setting for that in display settings -> edit display profile -> advanced tab -> Notify current layout
In Spring Signage cloud hosting it is disabled by default, because it might be really bandwidth consuming.
We can enable this option for you, just keep in mind that, it will consume bandwidth from your monthly allowance - how much depends on how many layout changes you have, how often it will be changed on the player etc.
If you want us to enable it for you, please let me know.
Thank you for your reply, i am happy to keep it as is as you suggested if enabled it will consume a lot more bandwidth
