Displays are not showing
https://xibo.org.uk/docs/setup/upgrade-and-switch-to-xibo-for-docker-install
So I followed the above guide carefully and able to login docker installation with the old username and password but displays are not showing in the dashboard, is this something you could help with?
Ameya
Please clear the cache and check again. If you still can’t see the Displays can you please confirm the following :
  • What version did you upgrade from/to
  • Were there any errors in the process?
  • Do any displays show in the schedule page of the CMS?
  • Are you the super admin of the CMS?
  • Are your layouts/media there as expected?
