Every display has a it’s own unique displayGroupId (hidden) and displayId, both you can get by calling GET display.
Then every actual displayGroup has a displayGroupId which you can get by calling GET displaygroup
the displayId on Displays page and displayGroupId on Display Groups page are also visible in web ui the displayGroupId of a individual display is not.
Hello, i know that you mean but it seems that every player by default is on own group (i have checked that via phpmyadmin) then i have add my player to the group and tryed via API get display but i cant find this
so the usual call is {{url}}/api/display
you can add ?display=DISPLAYNAME to the call to filter by display name (if you’d have more displays, it’s rather useful).
The thing that you want to add though is ?embed=displaygroups
so the full call for you {{url}}/api/display?embed=displaygroups
That will show you the “displayGroups” you mentioned in your post, there should be both the display own individual hidden display group as well as any display groups to which this display is assigned to.
