Hi all. I upgraded CMS from 1.7.6 to 1.8.0 alpha2 and I encountered some problems:
When I assign a layout to a display it will multiply the views for that display. It is displayed with the same id but for many times. How this works? I tried this because I wanted to set a default layout for a display but I didn’t find where. Another problem that I saw is when I want to edit a display to approve it the license, I can’t, it says: “Data missing”.
On version 1.8.0alpha3, we have same problem of “data missing” when trying to edit a display (note : this display also upgraded on version 1.8.0 alpha3, windows)
Message is
Application Message
Data missing
Here is the log file created: log_txt.pdf (162.4 KB)
