Hi.
We are trying to show the name of the room where our display is located, but i’m not sure if there is a better way to do it than using an overlay layout for each of the displays.
your advice would be greatly appreciated.
Hi.
Unfortunately it isn’t possible to put the name of the room as part of the layout, but your suggestion would work perfectly fine.
Thank you.
Its unfortunate, seems like a lot of work for 40 different displays, but still, thank you.
