Display is awaiting licensing approval from an Administrator - XIBO 1.8.7
Hello members,
I am new to Xibo, and I installed it on a server, and I tried to connect a display using on windows 10.
I have checked the Authorized to YES, and still the client keeps showing that same message…
I would appreciate your help.
That is perfectly normal message when you connect new player to the CMS.
Please log in to your CMS, navigate to the Displays page -> Edit display -> change ‘Authorise display?’ to ‘Yes’ and save the form.
Then on the player click save again it should say that everything is good, as such you can start the player.
