Display Edit API mandates the "display" field - 1.8.0-alpha
The Display Edit API forces the display field to be provided for no apparent reason. If this field is not passed, I get a
422 Unprocessable Entity
Can not have a display without a name
error. This is not a big issue but if I only have the displayId and wish to update the display, say only the description, I need to make an additional API call just to read the display name and then set it as part of my update call.
None of the API calls allow a “selective” update of fields, so selecting the current information is the way you should do it at present.
We might look into a selective update in the future, but we will keep things simple in 1.8 for now
