Display Description is not saved - 1.8 Alpha 2
The description for displays is not being saved.
Hi Colin,
You’re right, there is a typo in edit form code actually, no idea who did that… :scream:
So it’s not quite correct when you open edit form again.
Anyway, thank you for bringing this to our attention, issue number 666 logged.
:relieved:
Blimey - very festive!
Oh man… 666 You mean it doesn’t skip that number, like the 13th floor
At least the fix sounds simple enough. :grinning:
Note: I try to quote Peter on the first quote and it showed up as quoting Dan. Strange…
