I am playing with the forcast IO in order to see our it renders information.
I have selected French as a language and Standard international unit.
When I select the 5 days template, it display days abreviation as Fri, Sat, Sun,…
Has I have selected french language I was expected to get the it also in french Ven, Sam,Dim
Is tehre a way to display those in correct language ?
Mon = Lun
Thu = Mar
Wed= Mer
Tue =Jeu
Fri =Ven
Sat=Sam
Sun =Dim
In 1.8 series if you change the language of the forecast item it should show correctly in your selected language.
In 1.7 series that template requires additional steps:
In CMS settings, regional tab:
language - set your preferred language (in this case fr)
Change date format to - YYYY-MM-dd HH:mm:ss
tick the ‘Show international dates?’ checkbox
Now on the forecast item, set it to ‘5 days…’ template, tick ‘override template’ and then find:
