Different temperature reading is shown while using Forecast IO
I was exploring the Forecast IO feature.
While using it i faced different temperature reading.
There are two option available while entering latitude and longitude . We can either enter it manually or Use the Display Location.
Current temperature is around 36 degree celsius in my city.
While entering latitude and longitude manually the reading which i got was 37 degree Celsius.
But when option of “Use the Display Location” option the reading of temperature was 25 degree Celsius.
Why such a huge difference is being experience with different option for same feature.
What CMS version are you using please?
It should show the same temperature (assuming that your display location is the same as the location you entered in the forecast item)
