Different offset in cms for 2 client same pc
I would like to configure multiple monitors 1.7.2 cms (two in same pc) , but the 2 client installed on the PC (win7) has the same display ID, therefore can not make a different offset in cms. then I not see two different displays in cms. I await your comments. thank you. And thanks for sharing Xibo .
chris
So, if you want to use separate clients, you will also want to use 2 display profiles, which means you will want to edit hardware key (advanced - > display id).
Assuming that you already did this http://xibo.org.uk/manual/en/install_windows_client_multiple.html
You will want to open options for your second client and change the hardware key (display id)
Then you will have them both as a separate records in your CMS Displays page.
Which means you can define separate display profiles (with different offsets) and assign them to each player.
Hi ,
Peter, thank you very much for your quick response. information is very clear, and he mentions is the fastest and most optimal option for my work.
Thanks again
Great, I am happy I managed to help you :smile:
