On one of our layouts we have a lot of images.
Is it possible to set a default “Scale Type” to all of them at once?
Thank you.
Rich
Thank you.
Rich
Hi Rich,
Apologies for the delay, it seems we missed your post.
Unfortunately, I don’t think it’s possible, you’ll need to manually change it for each image.
Is there still no solution to this?
It would save me so many hours if this was to be implemented.
No, it was not implemented.
Generally I’d advise to have images in the same aspect ratio as the region in which you want to put them in - this way you will not need to use stretch scale type.
I’ve moved this topic to features category, so we will remember about it and it may be considered in the future development.
This would be a very good feature to get figured out. I agree with @JakeParnell that it would save much time, especially in a system where there are lots of updates (like mine). While I could hack the php that is not the right way to do it. A simple setting would be the best way to go.
