Hey Community,
I want to change the default display duration from images.
The default time is 10 sec. i want to change it on 86400 sec.
Does some one knows where i have to change it?
Thanks a lot!
Hey Community,
Thanks a lot!
I’m not sure if you want to set it that high, it can cause layout playback issues, not to mention that each image will be displayed for 24 hours…
In any case, to change the default duration you’d need to head to Modules page and edit Images module.
The above is correct for 1.8 series CMS.
