Hi! Is there any guide on installing xibo’s components on two seperate servers (namely Ubuntu 18.04)?
Shouldnt be any issue. During the set-up of XiBo you should be able to set the database servers address. Just choose the one of the external MySQL Server. You also have to have a separate admin user there, as remote login with root might be blocked
I’m having trouble getting the web server running. Do you mind helping me set it up in a non-docker environment on Ubuntu 18.04?
I’ve tried using the steps in https://xibo.org.uk/docs/setup/xibo-on-a-web-server but I keep ending up with a HTTP error 500.
Thanks!
