DB requirements question
I am being asked and I am not finding the answer so posting here…
Is PostgreSQL DB supported for xibo 1.8.x or newer? DB will be on a remote VM (not in a docker container).
If PostgreSQL is supported, which version?
Thanks!
Postgres isn’t supported by any version. MySQL is required.
