I’m trying to create a remote dataset that performs a get request from our JSON event feed. Our event feed doesn’t have a ‘data root’ - it’s just an array of objects, truncated sample:
"id": 6057,
"event_name": "RISE: Let's Talk Equity",
"event_description": "<p>Participants will be introduced to bystander intervention skills that they can use to prevent and respond to discrimination and harassment. It is recommended that participants complete this workshop before attending other RISE workshops. <a href=\"https://studentlife.ontariotechu.ca/services/equity-and-inclusion/events/index.php#tab1-3\">Registration </a>is required. </p>",
"event_categories": [
"event_tags": [
27
"event_startdate": "2021-06-15 15:00:00",
"event_enddate": "2021-06-15 17:00:00",
"all_day": false,
"open_to": [
29
"location_building": 0,
"location_room": null,
"location_campus": 2,
"location_id": 0,
"location_other": "Online"
"id": 6058,
"event_name": "RISE: Sexual Orientation",
"event_description": "<p>Participants will identify stereotypes based on sexual orientation (ie. lesbian, gay, bisexual, asexual, etc), and discuss known cases of discrimination and harassment that have targeted 2SLGB+ communities. <a href=\"https://studentlife.ontariotechu.ca/services/equity-and-inclusion/events/index.php#tab1-3\">Registration </a>is required.</p>",
"event_tags": [
27
"event_startdate": "2021-06-22 15:00:00",
"event_enddate": "2021-06-22 17:00:00",
"all_day": false,
"open_to": [
29
"location_id": 0,
When I try to create the dataset and select ‘Test data URL’ I get no response. However, if I enter anything into the Data root field, I get the full response.
Is a data root value required? What should I enter if there isn’t a specific root?
