Dataset three questions
I have three questions for which I can not find an answer to.
  1. In dataset I can only sort events by its ID. Is thery any way to sort the data using a different column, for example using start date of event?
  2. If I have a data set witch have start time, end time and library image, is there a way to display multiple images in one event? I mean, like in the picture.
  3. Is there a way to display one event on multiple screen ?
This is my dataset
1 - You will want to edit the column and select the checkbox Sort?
Then on View Data page you will be able to sort by that column.
2 - Ticker and DataSet view widgets show the data from DataSet, you can select which columns should be displayed and what filters should be applied then format the output.
Without any filters, if you select the column with Images they all would be displayed in the widget.
3 - If by one “event” you mean one Layout, then yes you can design the layout and then schedule it to multiple displays that are connected to your CMS.
