Dataset Question
2.3.1 Cloud supported
Windows WPF 5
R252
When I update my dataset the dataset table in the layout does not update after a direct updatenow call.
I update my dataset using the REST APIs. Additionally even after doing a “collectNow” REST call the display is still taking a minute to fetch the information from Xibo.
Ideally I am looking to see if the dataset table will update on it’s own without needing to do a change layout. On the layout the only item is the dataset table with a duration of 999.
This is for a “FIDS” (flight information display) demo screen.
Thanks,
Dan
This depends on the Widget you’ve used to display that dataset data - the Widget will have an update interval set on it, which determines how long that is cached for.
See the caching tab on the Widget.
