Dataset not being sync
Hi all,
Currently I have a dataset which is being used by a layout (as a ticker) which is scheduled as Always Showing on a display but somehow the data is not being sync. It only sync once when I set it up.
In the advance column of the dataset I’ve set it to refresh constantly.
Anyone have any idea on this?
Thanks!
Make sure you have setup XTR to be run regularly. It’s a background task that does the sync and if you’re not running XTR regularly it won’t be able to do that job.
