Dataset from external CSV in onedrive
Hi, i’m trying to auto import an csv located in my onedrive folder to dataset.
set Methode to GET and URL is the https://-> onedrivefolderfile.
i set the authentication to basic and set username and password correct.
the datasource is CSV.
but on test ULR data, i get: resulted in a 401 Unauthorized response.
What do i do wrong?
(i work at a school, and do not have acces to the xibo files on server, i’m an end user)
