Dataset filter depending on screen
Hi together
Herne i have 3 screens and one Layout wich Show Data from a dataset
Is there any was to Filter that Screen 1 only display Data with a specific row id
Same for screen 2 and 3
I dont warnt to usw 3 Different Layouts
I’m afraid you’d need to use separate layouts.
Filter on a dataset/ticker item will filter data from dataset on that item on that layout which is then send to players.
Make i column: name
For evert row, insert screen1, screen2, screen3 in name.
In ticker, make à filter:
name" ‘screen1’
Now u only get data from row “screen1”
hope I understood the question correctly :slight_smile:
