Dataset - Error Due to Empty Result Set with Filter Criteria
Hi there,
Just reporting an issue which you may have already planned to resolve in an upcoming Android Player Update.
Xibo 1.8 allows Tickers to be used with Datasets, with a message displayed when it is empty (great feature).
This works in the Preview Layout, but doesn’t work on the actual player (1.7 R60) as it won’t validate the layout.
Here is the error message from the CMS
Thanks! As far as I can see the error message here is that the “error message” is being logged incorrectly. The widget should go on from there and work as expected.
I’ve made a note to alter the error message to only get logged if there is no “no data” message.
