DataSet easy interaction
I would like to suggest an ideea for future developement regarding dataset. When admin wants to delete content from dataset, he can only manually remove the content from the cells. It would be nice if he can remove the row that he wants by pressing a button, instead of going at all cells and delete the text inside of them.
Have a nice day!
In 1.8 there is a (x) which you can press to delete whole row.
In 1.7 indeed there is no option like that, I am not sure if we will add it, but I moved your topic to appropriate section (features)
Can I download only the code that it does this functionality? Thanks.
